{"product_id":"lake-x-mercury-signature","title":"Canne Casting Lake X Mercury Signature 1m84  (30 - 100 g)","description":"\u003ch2\u003eAvis de la boutique\u003c\/h2\u003e\n\u003csection data-turn=\"assistant\" data-scroll-anchor=\"false\" data-testid=\"conversation-turn-2\" data-turn-id=\"request-WEB:39983959-5b49-4fa8-a8f4-29a66ea4c73a-0\" dir=\"auto\" class=\"text-token-text-primary w-full focus:outline-none [--shadow-height:45px] has-data-writing-block:pointer-events-none has-data-writing-block:-mt-(--shadow-height) has-data-writing-block:pt-(--shadow-height) [\u0026amp;:has([data-writing-block])\u0026gt;*]:pointer-events-auto [content-visibility:auto] supports-[content-visibility:auto]:[contain-intrinsic-size:auto_100lvh] R6Vx5W_threadScrollVars scroll-mb-[calc(var(--scroll-root-safe-area-inset-bottom,0px)+var(--thread-response-height))] scroll-mt-[calc(var(--header-height)+min(200px,max(70px,20svh)))]\"\u003e\n\u003cdiv class=\"text-base my-auto mx-auto pb-10 [--thread-content-margin:var(--thread-content-margin-xs,calc(var(--spacing)*4))] @w-sm\/main:[--thread-content-margin:var(--thread-content-margin-sm,calc(var(--spacing)*6))] @w-lg\/main:[--thread-content-margin:var(--thread-content-margin-lg,calc(var(--spacing)*16))] px-(--thread-content-margin)\"\u003e\n\u003cdiv class=\"[--thread-content-max-width:40rem] @w-lg\/main:[--thread-content-max-width:48rem] mx-auto max-w-(--thread-content-max-width) flex-1 group\/turn-messages focus-visible:outline-hidden relative flex w-full min-w-0 flex-col agent-turn\"\u003e\n\u003cdiv class=\"flex max-w-full flex-col gap-4 grow\"\u003e\n\u003cdiv data-turn-start-message=\"true\" class=\"min-h-8 text-message relative flex w-full flex-col items-end gap-2 text-start break-words whitespace-normal outline-none keyboard-focused:focus-ring [.text-message+\u0026amp;]:mt-1\" data-message-model-slug=\"gpt-5-3\" dir=\"auto\" data-message-id=\"1d3d1314-e896-4ac8-9703-d47ec8865c30\" data-message-author-role=\"assistant\" tabindex=\"0\"\u003e\n\u003cdiv class=\"flex w-full flex-col gap-1 empty:hidden\"\u003e\n\u003cdiv class=\"markdown prose dark:prose-invert w-full wrap-break-word light markdown-new-styling\"\u003e\n\u003cp data-is-only-node=\"\" data-is-last-node=\"\" data-end=\"388\" data-start=\"19\"\u003eLa Lake X Mercury - Signature est un véritable concentré de performance, conçu en partenariat avec Mercury Marine. Cette canne casting a été pensée pour la pêche du brochet au jerkbait (Buster, Slider, Deviant…) mais elle permet également de pecher le sandre en verticale lourde ou le brochet au shad. Robuste, efficace et dotée d’un design remarquable, elle s’inspire directement de l’univers et de l’identité de la célèbre marque américaine Mercury Marine.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/section\u003e\n\u003ch2\u003eUne collaboration Rodhouse et Mercury Marine taillée pour le jerk\u003c\/h2\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eBlank :\u003c\/strong\u003e Mama Buster (monobrin) fabriqué aux USA\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003ePuissance :\u003c\/strong\u003e 30-100 g (14-30 lb)\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eLongueur :\u003c\/strong\u003e 184 cm\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003ePoids : \u003c\/strong\u003e122g\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eMontage :\u003c\/strong\u003e Casting spiral avec anneaux Fuji Inox Sic\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eEspèces cibles :\u003c\/strong\u003e Brochet, Sandre\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eTechniques :\u003c\/strong\u003e Jerkbait buster, Verticale lourde\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003ePoignée : \u003c\/strong\u003eSplit grip en carbone, porte moulinet Fuji ACSM avec gâchette à 29cm du butt.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch2\u003eLa performance au service de la traque des grands brochets\u003c\/h2\u003e\n\u003ch3\u003eUne canne courte et puissante pour des animations millimétrées\u003c\/h3\u003e\n\u003cp\u003eLa Lake X Mercury - Signature repose sur le célèbre blank Mama Buster, une référence incontournable pour les amateurs de brochet au jerk. Sa longueur réduite de 184 cm est spécifiquement étudiée pour permettre des animations canne basse pour un leurre qui nage en \"side to side\". Vous pourrez ainsi imprimer des animations sèches et précises sans fatigue excessive, garantissant une nage irrésistible pendant des heures. En phase de combat, cette canne casting dévoile une action suffisamment ronde pour encaisser les coups de tête les plus violents. Cette souplesse contrôlée permet de limiter les décrochages tout en conservant une réserve de puissance nécessaire pour brider les spécimens.\u003c\/p\u003e\n\u003ch3\u003eUn montage technique avec une finition Mercury\u003c\/h3\u003e\n\u003cp\u003eLe design de cette canne reprend avec élégance les codes esthétiques de Mercury Marine, intégrant une poignée split grip en carbone et des ligatures avec liserets rouge et argent sur fond noir. Le montage des anneaux en inox avec céramique SIC est réalisé en spirale pour optimiser l'action du blank au combat. Cette configuration technique empêche la tresse de frotter sur le carbone et stabilise la canne lors des fortes tractions. Assemblée avec soin en France, elle bénéficie d'une qualité de finition haut de gamme qui souligne son caractère technique et robuste. Chaque détail a été pensé pour répondre aux besoins des pêcheurs exigeants.\u003c\/p\u003e\n\u003ch3\u003ePolyvalence : de la verticale lourde au lancer de shads\u003c\/h3\u003e\n\u003cp\u003eBien que sa spécialité soit l'animation des jerkbaits, la Lake X Mercury - Signature est une canne polyvalente pour un pêcheur de carnassier.  Sa puissance de 30-100g permet de propulser efficacement des \u003cstrong\u003eshads de 18 cm\u003c\/strong\u003e lorsque les poissons boudent les leurres durs. Lors des épisodes de crues, elle se transforme en un outil redoutable pour la pêche du sandre en verticale avec des têtes plombées pesant entre 50 et 100g. Cette capacité à supporter des montages lourds, couplée à l'usage du live, en fait une alliée précieuse pour les pêches hivernales du sandre. \u003c\/p\u003e","brand":"Rodhouse","offers":[{"title":"Default Title","offer_id":56859778777466,"sku":"Lake X Mercury - Signature","price":266.67,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0754\/3000\/3004\/files\/vue-1_feb8e899-a406-49e7-a0dd-023709646df8.png?v=1778060691","url":"https:\/\/rodhouse.com\/products\/lake-x-mercury-signature","provider":"Rodhouse","version":"1.0","type":"link"}
