The right blank selection for bottom-scratching
When it comes to fooling predators that feed on the bottom or hold right above it, bottom-scratching is a first-class presentation. To be effective—and avoid constant snagging—it requires solid technique and specialized gear that enables precise lure work and abundant feedback.
La bonne sélection de blanks pour la pêche  à gratter
A flagship presentation for zander, meagre, and many other predators such as European seabass, bottom-scratching is a technique often used by lure anglers to fool fish that hold on or near the bottom. While this approach is very effective, it forgives few approximations: poor line control inevitably leads to frequent snags. To boost results, a suitable, high-quality rod is essential.
The animation pattern
Bottom-scratching originates in imitating benthic prey such as crustaceans (crabs, shrimp, crayfish, etc.), larvae, or certain fish species (gobies, wrasse, gudgeon…). At the same time, many whitefish feed on the bottom; presenting a lure tight to the substrate and making it “root around” therefore reproduces a natural behavior of potential prey.
The goal is to work the lure—generally a soft bait on a jighead—in short hops, glides, or by letting it tumble with the current a few centimeters above bottom, with regular bottom contacts.
The demands of bottom-scratching
Anyone who has tried it knows it produces many snags when the bottom is rugged and the feedback is vague: poor control of slack, bad casting angle, unsuitable jighead weight, etc.
Your tackle must therefore deliver maximum feedback: bottom reading as well as bite detection—sometimes extremely subtle.
While a fine 8-strand braid is a given, the rod remains the key component for fishing this technique properly.
Your tool must also allow effective line control—that is, managing line tension—and very precise animations in amplitude, speed, and reactivity.
Finally, because you’ll use exposed hooks (often heavy-wire) or hooks shielded by the lure or a weedguard (rubber jig), your rod must ensure decisive hook-sets.
Traits of the ideal blank
Given these demands, go for a high-modulus carbon blank—lightweight, but above all highly resonant and sensitive. Such modulus is often paired with fast actions and high tip frequency: undeniable assets.
To execute precise animations, drive hooks home in hard jaws, and read bottom and bites as well as possible, a fast tip action—even extra-fast—is a must.
It’s wise to favor a firm-tipped model and to work in the lower to middle part of the blank’s power range to preserve animation precision.
A stiff blank—i.e., with a high return frequency to its initial position—is also essential to perform in this style of fishing.
As for length, choose models from 6.6 ft to 7.6 ft depending on the environment and whether you’re fishing from shore or a boat.
Other possible applications
The ideal characteristics described above are also those recommended for “on-the-drop” fishing. At sea, the same tool therefore lets you alternate dynamic mid-water work—searching for active seabass, for example—and slower presentations on the bottom.
Suitable blanks
There are many suitable references for effective bottom-scratching.
From MHX, the 842 and 843 are first-rate models.
Rodbuilder’s Republic’s Statement 724, 725, and 727 have already earned a strong reputation among seabass and zander anglers who like to probe near the bottom.
From NFC, consider the 703, 705, as well as the X-Ray 736 and 733.
Finally, at Phenix, the K2 series brings together very resonant, fast models.
