Don't know how to place your rings on your fishing rod? If this is your first time, don't worry, it's perfectly normal. You may be wondering what size to choose and how much distance to leave between the different rings. Here's our video tutorial to give you more information on ring placement:
The easiest way for a first rod is to follow Fuji's specifications. They will tell you the number of rings to place on your rod, their size and the spacing to allow.
Find the Fuji specification at this address: Fuji specification
How a Fuji specification looks
For a 7-foot (2m13) blank, you choose the most suitable specification based on the length. For example, at 11 cm from the tip, you'll place a size 6 ring, at 12 cm a size 8 ring, and so on.
For your first rod, it's really worth following these specifications. They are proven, reliable and give very good results.
How to place your rings
Following the specifications, use a white pencil to mark your measurements. The white marks will indicate where you will install your rings, which you will then Wrapping in that location.
Our next tutorial will show you how to tie your rings.
0Log in to leave a comment.
Log in
