Education
Repairing a fishing rod: A complete guide to restoring your equipment
A practical guide to repairing your fishing rod. Learn how to repair common damage to extend the life of your rod.
Réparer une canne à pêche : Guide complet pour restaurer votre équipement
Repairing a fishing rod.
Today I'm offering a tutorial that will show you how to repair a fishing rod broken at the butt.
This area of the rod, unlike the tip, is not subject to heavy stress. The repair therefore simply involves "sleeving" the two pieces of rod.
To do this, I simply use:
  • A striped trunnion with a diameter almost equivalent to the rod's internal diameter;
  • a carbon tube for finishing, slightly larger in diameter than the rod;
  • Two-component Epoxy glue, here from Tuff Glue Rodbuilder's Republic.
Sleeving a broken heel
The striped trunnion can easily be found in DIY stores.
The carbon tube will provide a finish worthy of the name.
So I start by removing two decorative Wrappings that will get in the way of my carbon tube. I take the opportunity to lightly sand the rod in preparation for the glue.
I then cut a piece of trunnion about ten centimeters long, trace its middle, and coat one of the two parts with glue.
I position this trunnion in one of the two parts of my broken cane.
I then let it dry while my glue sets well. Repairing a fishing rod requires a bit of patience and application, but it's really within everyone's reach!
Once dry, I coat my two pieces of cane with glue and thread my carbon tube over them.
I let it dry and that's it! It's finished!
Not so complicated after all ;-)
Find our tutorial on The technique for safely dismantling a fishing rod!
4
  1. Bien entendu qu’il est autorisé de monter sa canne à pêche et de l’utiliser ! tout comme on a le droit de fabriquer ses propres leurres, ses propres flotteurs, ou de monter ses propres mouches pour un moucheur !
  2. Bonjour je sais que ce n’est pas le sujet ,mais est ce quand france ont as le droit de fabriquer sa canne sois meme et d’utiliser ? Car ont ma dit non mais je prefere venir me renseigner a d’autre source
  3. Bonjour. On peut tout à fait remplacer le tourillon par un tube carbone, comme ceux utilisés pour le modélisme. Le tourillon a l’avantage de ne pas couter cher 😉
  4. Bonjour on peu faire ça aussi avec un tube Carbonne
