Blank LMX ST 865-4 2m59 (3 - 15g)
Tabele pomiarowe
Tabele pomiarowe
| 5 | 13.15 |
| 10 | 13.15 |
| 15 | 13.15 |
| 20 | 13.15 |
| 25 | 13.15 |
| 30 | 13.15 |
| 35 | 13.15 |
| 40 | 13.15 |
| 45 | 13.15 |
| 50 | 13.15 |
