Guide d'achat
Choosing the Right Rod Handle Length: Standards and Tips
Choisir la longueur de talon de sa canne à pêche : Standards et Conseils
Choosing the right handle length for your fishing rod is a crucial step that often determines the success of your fishing sessions. This dimension directly impacts comfort and the efficiency of your lure presentation on every outing. Whether the rod is too short or too long, poor ergonomics can quickly make fishing tiring.
Thanks to rodbuilding, it is possible to adjust this length down to the millimeter to suit your specific needs. This article details current standards based on target species and fishing techniques to help guide your choice.
Understanding the importance of handle ergonomics
The handle length is not just about aesthetics; it influences the overall handling of your gear while fishing. Although standards exist depending on the technique, everyone is free to adapt this length to their own body type, fishing style—whether standing or sitting—and personal habits.
A well-adjusted handle allows for more accurate casts and reduces strain on your joints during fights with fish. By customizing this part of the rod, you optimize the leverage required for each specific fishing technique.
How to properly measure handle length?
To ensure an accurate measurement consistent with manufacturer recommendations, a specific method must be followed depending on the type of reel used. Handle length is not measured across the total length of cork or EVA, but from fixed pivot points.
  • For spinning, the measurement is taken from the butt (the lower end of the rod) to the reel foot.
  • For casting, the measurement is taken from the butt to the trigger located on the reel seat.
This distinction is essential because it reflects the actual position of your dominant hand when holding the rod, ensuring perfect balance.
Standards for predatory fish in spinning techniques
In spinning, handle lengths vary greatly depending on the blank length and rod power. For finesse fishing such as trout, shorter handles are often preferred to facilitate underhand casts in tight environments.
Conversely, for species like sea bass or catfish, longer handles are needed to ապահով a solid grip and sufficient leverage for long-distance casting or powerful fights.
Here is a summary table of recommended handle lengths for spinning:
Fish / Technique Blank length Power Handle length Example Blank
Trout (Hard bait / Spinner) 1.82 m – 1.98 m < 10 g 20 cm FW 662-2 IM
Trout (Hard bait / Spinner) 2.13 m – 2.28 m < 15 g 29 cm FW 704-1 IM
Trout (TOC) 3.05 m – 3.96 m < 15 g 15 cm ST 1302-2 Delta
Zander (Vertical) 1.87 m 7–35 g 29 cm PPS 62 MH
Zander (Linear) 2.18 m – 2.30 m 5–25 g 32 cm Statement 724
Zander (Linear) 2.43 m – 2.59 m 10–35 g 35 cm MB 805 HM
Perch (Jigging Rap) 1.87 m 5–25 g 27 cm IMMWS 62 MX
Perch (Drop shot / Bottom fishing) 2.13 m – 2.28 m 3–12 g 31 cm Statement 722
Catfish (Vertical / Lure) 1.82 m – 2.13 m 50–150 g 43 cm RCLB 70 XL
Catfish (Live bait / Lure) 2.50 m 40–120 g 46 cm Fifty Niner
Sea bass (Topwater / Bottom) 2.13 m – 2.21 m 5–30 g 32 cm MB 705 HM
Sea bass (Retrieve) 2.43 m – 2.59 m 20–60 g 37 cm MB 807 HM
Sea bass (Shore casting) 2.90 m – 3.05 m 15–85 g 40 – 48 cm Suzuki 9.6' / 10'
Handle setup for casting gear
Casting gear requires a different approach, especially for techniques like “Big Bait” or “BFS” (Bait Finesse System). The presence of a trigger on the reel seat changes the grip and often requires a longer handle to brace the rod under the forearm when using heavy lures.
For pike or black bass fishing, handle length helps balance the overall setup and makes powerful hooksets easier by leveraging against the elbow.
Here are the references for the main species targeted in casting:
Trout (BFS) 1.63 m < 10 g 14 cm PPS54UL
Zander (Vertical) 1.87 m 7–35 g 28 cm PPS 62 MH
Zander (Linear) 2.18 m – 2.30 m 5–25 g 28 cm Statement 724
Pike (Jerk / Frog) 1.82 m – 2.21 m 10–80 g 29 – 31 cm Mama Buster
Pike (Swimbait) 2.21 m – 2.74 m 20–220 g 34 – 50 cm MB 739 IM / SWB 909-2
Black bass (Rubber jig) 1.98 m – 2.25 m 7–35 g 29 cm PPS 66MH
Pollock (Slow jigging) 1.98 m 50–200 g 42 cm REVSJ 66 M
Distance rods and heavy fishing: Feeder, Carp and Exotic fishing
For techniques requiring very long casts such as surfcasting or carp fishing, the handle becomes a true lever. The longer and more powerful the blank, the longer the handle needs to be to allow maximum casting motion and properly load the rod.
In exotic fishing, the choice of handle length is also influenced by whether or not a fighting belt is used, as this changes the angler’s support point during the fight.
Below are the specifics for these disciplines:
Feeder 10' – 13' (3.05–3.90 m) 50 – 110 g 45 – 53 cm IN-MF Series
Carp 9' – 13' (2.74–3.90 m) 110 – 130 g 50 – 66 cm CPS / ATREX Series
Exotic popping (with belt) 2.13 m – 2.51 m 50 – 150 g 48 cm Giant 7'
Exotic popping (without belt) 2.13 m – 2.51 m 50 – 150 g 50 cm Giant 7'
Exotic shore casting 3.20 m 90 – 180 g 61 cm Nano Heavy 10'6
Exotic jigging 1.57 m – 1.82 m 100 – 250 g 45 cm Cape Cod 58-250
Surfcasting 4.20 m – 4.50 m 50 – 200 g 84 cm SP42-200
