When you spend several hours on the water, comfort is no longer enough. A fishing garment also has to shield you from the sun, breathe, dry fast and follow your movements instead of holding them back.
Those are the constraints PELAGIC built its technical range around, designed for anglers exposed to sun, heat, humidity and constant movement. That leaves the labels sewn into the garment: UPF 50+, Quick Dry, 4-Way Stretch, DWR. What do they actually change once the shirt is on your back?
On the water, the sun reaches you twice: directly, then reflected off the surface. Your skin takes it continuously.
Most PELAGIC technical garments therefore include UPF 50+ protection. That certification means the fabric blocks at least 98 % of the UV rays concerned.
The benefit works both ways: you cover more skin, and you avoid having to constantly reapply sunscreen to your arms, shoulders or back. Over a full day, a long-sleeve technical shirt keeps you covered without overheating.
Some models go further. The Exo-Tech adds face protection through its mask, for coverage announced at 360°.
Casting, setting the hook, fighting a fish, leaning over for the net, shifting position on the boat: fishing keeps you moving constantly. The 4-Way Stretch fabrics PELAGIC uses stretch in several directions, so the garment follows the movement instead of limiting it.
It is the kind of detail that seems minor when you try a shirt on for a few minutes in a shop, and becomes obvious after several hours of casting.
Heat and humidity are the two enemies of comfort on the water. A garment that stays damp quickly turns heavy, clingy and unpleasant. PELAGIC therefore uses fabrics that wick moisture away and speed up drying, a technology highlighted on the Aquatek and Vaportek ranges.
After heavy sweating, a splash of water or an accidental dunking, the fabric quickly feels dry again. The Vaportek pushes this logic furthest, with an ultralight fabric that still keeps UPF 50+ protection and stretch.
Protecting yourself from the sun does not mean cooking underneath. PELAGIC garments include vented zones placed where the body heats up, under the arms or across the back depending on the model, letting air circulate while the fabric covers the skin.
It counts most in high heat, where taking off a layer to cool down means exposing yourself further.
Some PELAGIC garments also receive a DWR (Durable Water Repellent) treatment. The principle: water beads on the surface of the fabric and slides off instead of being absorbed straight into the fibres. The brand currently uses a C0 DWR, presented as PFAS-free, which also brings stain resistance.
It obviously does not turn a technical shirt into a waterproof jacket, and that is not the point. The aim is to limit how far small splashes penetrate and to make the garment easier to look after. For an angler regularly exposed to spray, splashes and fish slime, the difference shows quickly.
PELAGIC does not build its whole collection around a single fabric. The brand offers several constructions depending on use.
Aquatek, versatile comfort
The Aquatek plays comfort and versatility above all. Its ultra-soft 100 % nylon fabric combines UPF 50+ protection, quick drying, 4-way stretch, ventilation and a PFAS-free water and stain repellent finish. It is the most obvious base for long summer fishing days, when what you mainly want is something light and protective.
Vaportek, lightness first
With the Vaportek, the emphasis is on lightness and fast drying. The ultralight, stretchy and breathable fabric targets hot conditions where every gram counts, while keeping UPF 50+ protection and the C0 DWR finish. It is the kind of garment you end up forgetting you have on, including on a long day of trolling for tuna.
Exo-Tech, maximum coverage
The Exo-Tech takes a different approach: rather than protecting the torso and arms, it aims to cover the angler as fully as possible. Integrated face mask, UPF 50+ protection, ventilation, zippered pockets and DWR finish make it a choice for anyone spending long hours exposed to the sun.
Freespool, between fishing and lifestyle
The Freespool range brings the technical garment closer to everyday wear. Its recycled stretch fabric combines UPF 50+ protection, breathability, moisture wicking and quick drying. Depending on the model, you also get a snap hood, a kangaroo pocket and thumb holes. You keep the essentials of a fishing garment in a piece that works just as well on land as on the water.
None of these technologies does the job on its own. UPF 50+ shields you from the sun, 4-Way Stretch preserves freedom of movement, Quick Dry speeds up drying, Moisture Wicking pulls humidity away, Venting improves airflow, C0 DWR repels water and limits stains. Each one answers a specific constraint the angler runs into, and it is their combination that makes the difference over a long session.
A genuinely technical garment is not only trying to feel pleasant to wear. It has to let you stay focused on your fishing, whatever the conditions.
There is no single PELAGIC garment that suits every situation. For a hot day where versatility and comfort come first, the Aquatek is a solid base. When the heat builds and you want the lightest, fastest-drying option, it is the Vaportek.
For long sessions under intense sun, when coverage matters more than anything else, the Exo-Tech offers the most complete protection. And to keep the performance of a technical garment with a style that also works on land, there is the Freespool.
That leaves the head: a vented cap or a hat covers the face and scalp, two areas no shirt reaches. The rest of the selection sits in the fishing clothing category.
The best garment is the one you forget
A good fishing garment protects without trapping heat, follows your movements without getting in the way, dries fast after a splash and stays comfortable after several hours under the sun. You end up not thinking about it at all.
That is the logic behind PELAGIC's garments: start from the constraints anglers meet on the water and turn them into concrete textile solutions, so a long day of fishing is not cut short by the wrong piece of clothing.
0Log in to leave a comment.
Log in
