Débutant
Tutorial: How to embellish your ligatures with a trim band
Ligatures are undoubtedly the means by which rod builders most personalize and “embellish” their fishing rods. To achieve this, there is no need to be an expert or to devote a significant amount of time, as it is within everyone’s reach to decorate their ligatures with a trim—as we have already seen—or with a more or less subtle colored band within them. Here is how to create this final ornament, called a trim band.
Tutoriel : Comment embellir vos ligatures d'un trim band
Techniques and steps to add a trim band to your ligatures
In a previous post, we discovered how to embellish the ends of your ligatures. In this tutorial, we will focus on the body of them by adding a trim band. This technique involves inserting a thread of a different color to create a band that is more or less contrasted and wide.
Table of Contents
Creating a full trim band
Step 1: Start your ligature
  • Pass your main thread over itself from left to right.
  • Maintain tension and make the first turns.
  • After 6 or 7 turns, your ligature is securely in place.
Beginning of the ligature
Step 2: Preparation of the colored thread
  • Twelve turns before the trim band position, place a colored thread under a coil.
  • Secure it parallel to the blank using painter’s tape.
  • Continue the ligature with constant tension.
  • Cut the excess and adjust if necessary.
Placement of the colored thread
Step 3: Positioning the colored thread
  • Pass the colored thread over the main thread, from right to left.
Passing of the colored thread
Step 4: Creating the trim band
  • Make a first turn parallel to the main coils.
  • Maintain the tension for a clean finish.
First turn of the trim band
Step 5: Adding additional turns
  • Perform several turns while keeping them even.
  • Ensure that the coils do not overlap.
Additional turns of the trim band
Step 6: Securing the colored thread
  • Pass the colored thread under the main thread perpendicularly.
Step 7: Locking the trim band
  • Make an extra turn with the main thread to secure the band.
Step 8: Finalizing the ligature
  • Continue the ligature by compressing the coils using a burnisher.
  • After 5-6 turns, cut the excess colored thread.
Finalization of the ligature
Step 9: Final locking
  • Finish your ligature as usual.
Final locking
Step 10: Varnishing
  • Cut the excess threads and refine your ligature.
  • Your trim band is ready for varnish application.
Finished ligature
Creating an alternating trim band
  • The first three steps are identical to those of the full trim band.
Step 4: Parallel positioning
  • After passing the colored thread, keep it parallel to the main thread.
  • Squeeze both threads between your thumb and index finger.
Holding the colored thread
Step 5: Alternating the threads
  • Perform the desired number of turns while alternating the two threads.
Step 6: Securing the trim band
  • Pass the colored thread under the main thread.
  • Add one turn with the main thread to secure the assembly.
Step 7: Continuing the ligature
  • Continue by firmly compressing the coils with a burnisher.
  • Cut the excess colored thread after 5-6 turns.
Step 8: Finishing and varnishing
  • Finish and secure your ligature as usual.
Finishing
Step 9: Finalization
  • Cut the excess threads and compress the coils one last time.
Finalized ligature
Products of this article
SKU brunissoir-lime green
Brand Rodbuilders' Republic
Weight (g) 6.0
Brunissoir
2,70€
Frequently Asked Questions
How to choose the right size of Wrapping wire?
Size A lines are recommended for Fly fishing rods and for carnivorous lightr. Size D line, on the other hand, is recommended for stronger fishing.
