Building your own rod wrapping jig: a step by step plan
Building a rod wrapping jig takes little more than a board, a few brackets and some felt. Here is the build plan, the tension setting and the limits of the home made version.
The varnish applied to a wrap primarily acts as the “cement,” permanently fixing wraps and any associated guides. But its glossy finish also enhances and add...
Once you’ve mastered the basic ornaments—pinstripes and trim bands—the next step in discovering “wrapping” is making slightly more complex bindings such as o...
Ligatures are undoubtedly the means by which rod builders most personalize and “embellish” their fishing rods. To achieve this, there is no need to be an exp...
As soon as the pleasure derived from the success of your first bindings is felt, the desire to enhance and add complexity to them naturally arises. Instead o...
Discover the art of wrapping with Jérôme Barnouin, a Rodhouse expert. Learn his techniques, tips, and tricks to customize your rods with unique and high-perf...
Learn how to create your first Fish Scale wrap with this detailed tutorial by Jérôme Barnouin. Discover how to mark patterns, choose the right threads, and m...
Bienvenue dans notre guide sur la concordance des couleurs des fils à ligature. Ce guide vous aidera à choisir les bons fils à ligatures pour vos futurs mont...
Building a rod wrapping jig takes little more than a board, a few brackets and some felt. Here is the build plan, the tension setting and the limits of the h...
Follow this tutorial to make sparkler-shaped Wrappings on your fishing rods. Add a touch of elegance and creativity to your creations.
