Amegari
Fishing Bluefin Tuna with Lures in Brittany: Techniques, Season, and Recommended Gear
La pêche du thon rouge au leurre en Bretagne : technique, période et matériel recommandé
The Bluefin Tuna: a legendary fish of extraordinary size
The bluefin tuna is an iconic fish of the Atlantic and Mediterranean oceans. A powerful migrator, it can exceed 3 meters in length and weigh up to around 600 kg. A true sprinter of the seas, this spectacular predator was long threatened by overfishing, but is now making a strong comeback, much to the delight of sport fishing enthusiasts.
Why is fishing tuna on the chase so captivating?
Fishing tuna on the chase is a unique, adrenaline-packed experience. When tunas pursue schools of baitfish at the surface, they create impressive turbulence known as “whirlpools.” This visual and fast-paced style of fishing demands quick reactions, endurance, and perfect mastery of the gear. It appeals to anglers seeking thrills and muscular fights with a formidable opponent.
In this article:
  • Ideal season for chasing bluefin tuna
  • Techniques and approach strategies
  • Recommended gear (rods, reels, lures, etc.)
  • Fishing areas and regulations
When to fish bluefin tuna on the chase?
Season Calendar 2025
The bluefin tuna fishery is regulated by strict rules. In 2025, the no‑kill period runs from early June to mid‑November. Harvesting (“kill”) is allowed from July 11 to October 10. In Brittany, the first tuna appear in early July, with the peak season running from July 20 until the first autumn storms (around mid‑October).
Regulations to know
  • A DDTM authorization is required for no‑kill fishing (apply between April and May).
  • To keep a tuna, you must obtain a tag, usually through an affiliated association.
  • Minimum legal size: 1.15 meters or 30 kg.
  • See the full law text on Legifrance.
Favorable conditions for bluefin tuna fishing
Weather and Navigation
Tuna typically hunt over seabeds at least 35 m deep. Depending on the area, you may need to cover several nautical miles. Good weather conditions are therefore essential for safety and efficient spotting.
Spotting a tuna chase
Tuna often move in schools and create spectacular surface activity. They can be located by:
  • Surface boils
  • The presence of seabirds feeding
  • Behavior of dolphins or other predators
What gear for chasing bluefin tuna?
Spinning rods
Matching the rod power to the size of the target fish is crucial:
Reels
A strong drag (20–30 kg) and high line capacity are required:
  • Size 14000: ideal for tuna up to 60 kg
  • Size 18000–20000: for tuna of 60 kg and up
  • Size 30000: useful for live bait fishing or very deep water
Braided line & shock leader
Use braid matched to the rod’s power: PE6, PE8, PE10. Avoid 12‑strand braids. A shock leader of about 2.20 m is tied to the braid with an FG knot. Fluorocarbon is preferred for live bait rigs.
Lures
Must-have lures in your tackle box:
Essential terminal tackle accessories
Tip: Keeping a split ring on each lure prevents over-opening when changing them. Less wear, more efficiency!
Tips to maximize your chances
Spotting fish and discretion
A pair of stabilized binoculars is an excellent investment for spotting chases from up to 6 nautical miles away. Pay attention to bird behavior and other boats.
Approaching chases
Approach chases quietly or, conversely, attempt a swift pass. Adapt your strategy to the fish’s behavior.
Ideal timing
In some coastal areas (e.g. the Glénan Islands), chases follow a strict rhythm: dawn session, break at 11 am, resume around 6 pm. Offshore, the pattern can vary entirely.
Where to fish bluefin tuna in France?
  • Mediterranean: tuna present year-round
  • Atlantic Coast: season starts in June
  • Brittany: mid‑July
  • Normandy: early August
  • Hauts‑de‑France: mid‑August
Our Rodhouse special selection for bluefin tuna
Discover our special packs dedicated to tuna chase fishing. Everything you need to be ready on the big day.
Conclusion
Fishing bluefin tuna on the chase is a unique adventure combining strategy, strength, and passion. Good preparation, suitable gear, and precise observations make all the difference.
For technical questions or personalized advice, contact us at contact@rodhouse.com.
👉 Share your experiences, photos, or questions in the comments below.
📬 Subscribe to our newsletter to never miss our upcoming articles!
Products of this article
SKU Nano7'6
Brand Black Hole USA
Range Popping
Weight (g) 224.0
Target species Giant trevally, Yellowfin tuna, Bluefin tuna
Recommended techniques Popping, Exotic fishing
Action Moderate-Fast
Length (cm) 229.0
Mounting Exotic
Number of pieces Butt joint
Blank power 50-150 g (50-80 lb)
Butt measurement (mm) 18.4
Tip measurement (mm) 3.6
Packed size (cm) 162.0
Recommended tip 16-3.6
Cape Cod Special 7'6 Nano
299,00€
SKU RXGT-7102
Brand Suzuki
Range RXGT
Weight (g) 250.0
Target species Bluefin tuna, Yellowfin tuna, Exotic species
Recommended techniques Exotic fishing, Popping
Length (cm) 238.0
Mounting Exotic
Blank power 200 g (100 lb)
Butt measurement (mm) 20.3
Tip measurement (mm) 2.6
Recommended tip 12-2.6
RXGT 7102
420,00€
SKU Cow Special GEN II
Range Black Hole - Popping
Weight (g) 328.0
Recommended techniques Popping, Live bait, Exotic fishing
Length (cm) 220.0
Category Exotic fishing
Number of pieces One-piece
Blank power 70-300 g (130 lb)
Butt measurement (mm) 24.26
Tip measurement (mm) 4.0
Recommended tip 16-4
Cow Special GEN II
(7)
396,00€
SKU TPSW14000XGC
Brand Shimano
Weight (g) 660.0
Mounting Spinning
Retrieve (cm) 134.0
Twin Power 14000 SW C XG
579,90€
SKU Bonito 130-Anchovy
Brand Crealures
Weight (g) 71.19
Target species Yellowfin tuna, Bluefin tuna
Lure type Stickbait
Crealures Bonito 130
35,00€
SKU TPB01600
Brand Kerfil
Weight (g) 50.0
Target species Yellowfin tuna, Bluefin tuna, Exotic species
Number of pieces 1
Jig Head Kerhy Thon
10,20€
SKU MJIG02-BRC-100-1
Brand Mustad
Weight (g) 100.0
Target species Cod, Trevally, Exotic species, Amberjack, Yellowfin tuna, Bluefin tuna, Pollack
Recommended techniques Sea jigging
Lure type Jig / Casting jig
Jig Mustad Daggerman
14,90€
SKU Big Game Rolling L160-2
Brand Rodbuilders' Republic
Weight (g) 4.55
Length (mm) 16.5
Émerillon baril Big Game Rodbuilders' Republic
5,70€
Frequently Asked Questions
Quelle est la différence entre une pêche au thon "sur chasse" et une pêche au thon "au vif" ?
La pêche "sur chasse" consiste à repérer les bancs de thons en train de traquer les poissons fourrage en surface (sardines, lançons, anchois…), puis à lancer rapidement un leurre à proximité de l'action. C'est une pêche très visuelle, basée sur l'observation.
La pêche "au vif", quant à elle, utilise un poisson vivant (appât) comme appât fixé à un hameçon, et est souvent pratiquée en profondeur ou en dérive. Elle nécessite moins de rapidité et d’observation, mais plus de patience.
