Bar
Spotlight on the WKS Statement 722: Finesse Fishing Excellence by Rodbuilders' Republic
Zoom sur la WKS Statement 722 : L’excellence de la pêche finesse signée Rodbuilders' Republic
If you’re looking for a rod capable of transmitting the slightest vibration from the bottom while still offering a surprisingly strong power reserve, you’re in the right place. Today, we introduce the WKS Statement 722, one of the flagship models of the “Statement” series distributed by Rodbuilders' Republic.
An Exceptional Blank Born in the USA
The Statement 722 is built on a blank manufactured by North Fork Composites (NFC) in the United States, a global benchmark in the rodbuilding world. Measuring 2.18 meters in length and rated for 3 to 15 grams (ML), it is the lightest model in the Statement range.
What truly defines this blank is its extreme sensitivity. Designed to deliver outstanding feedback, it excels in bottom-contact techniques. Its one-piece construction and Fast action ensure instant responsiveness, while providing a rounder, more “forgiving” action during the fight to prevent hook pulls.
Performance: Freshwater vs. Saltwater
Versatility is one of this rod’s greatest strengths, although the perceived power may vary slightly depending on the environment:
  • Freshwater: Ideal for perch and light zander fishing. It performs perfectly with 3- to 4-inch soft baits rigged on 3 to 9 g jig heads, as well as for Ned rig applications.
  • Saltwater: A reliable ally for kayak sea bass fishing or sight fishing in estuaries.
In real fishing conditions, freshwater anglers will typically rate it closer to a 3–12 g range, while in saltwater it is perceived as a 5–15 g rod.
An Unexpected Power Reserve
Don’t be fooled by its light weight. The Statement 722 features a tapered blank with a wide butt section, giving it an impressive power reserve. As proof, a member of our team recently managed to land an 87 cm sea bass with this model.
High-End Components: Comfort and Technology
When it comes to the build, quality is front and center, with components selected for both performance and durability:
  • Solid carbon handle: A signature of the WKS Prodigy range, ensuring optimal vibration transmission.
  • Fuji VSS16 reel seat: Specifically chosen for its comfort during light and finesse techniques.
  • Fuji Titanium Torzite guides: Built according to the KR Concept (3-guide reduction train), delivering lightness and perfectly smooth line flow.
  • Featherweight: The rod weighs just 100 grams.
Conclusion
Priced at €469.00, the WKS Statement 722 is a precision tool for anglers passionate about finesse techniques. Whether you’re targeting chub, perch, or sea bass in estuaries, it turns every subtle bite into a true adrenaline rush.
Key specifications:
  • Length: 218 cm
  • Power: 3–15 g
  • Action: Fast
  • Line rating: 6–12 lb
  • Manufacturing: NFC USA
  • 30 cm butt section, perfectly sized for finesse presentations.
Products of this article
Spinning Rod WKS Statement 722 2m18  (3 - 15 g)
SKU WKS-STATEMENT 722
Brand Rodbuilders' Republic
Range Prodigy WorkShop Series
Weight (g) 100.0
Target species Sea bass, Trout, Zander, Perch, Shad
Recommended techniques Finesse, Jerkbait minnow, Kayak, Straight retrieve, Bottom dragging
Action Fast
Length (cm) 218.0
Mounting Spinning
Number of pieces One-piece
Blank power 3-15 g (6-12 lb)
Ceramic Torzite
Frame Polished Dark Grey
469,00€
