Building your own rod wrapping jig: a step by step plan
Building a rod wrapping jig takes little more than a board, a few brackets and some felt. Here is the build plan, the tension setting and the limits of the home made version.
Two Rodhouse Pro-Staffs, two strategies against the Bréhat currents: discovering new water for one, meticulous pre-fishing for the other. The story of a dema...
Mid-strolling is a Japanese finesse technique that targets suspended fish with a soft lure worked through the mid water column. Here are the method, the gear...
Same DNA as the legendary Statement 724, but with a power that changes everything. The WKS-Statement727 pushes the concept up to 50 g and opens the door to d...
Depending on the brand and blank series, the casting weights indicated by manufacturers (often in oz) are not always consistent. This is why Rodhouse provide...
A favourite among trolling bass anglers, the WKS-MB807-1HM owes its reputation to nothing but merit. Cutting-edge technology, unique sensations and formidabl...
If you had to choose just one rod for your pike fishing sessions, it would undoubtedly be the WKS-MB 739-1 IM. A true marvel of versatility from the Rodbuild...
If you’re passionate about pike fishing with swimbaits, you know that choosing the right rod is crucial to combining casting comfort with hook-setting effici...
If you’re looking for a “light” rod that can turn every vibration into an electric jolt in your wrist, you’ve come to the right place. Today, we present the ...
If you’re looking for a rod capable of transmitting the slightest vibration from the bottom while still offering a surprisingly strong power reserve, you’re ...
