Blank LMX FW 763-4 2m29 (5 - 20g)
En rupture
SKU: LMX-FW763-4 Calcul en cours...
Prix de vente 191,40€
SKULMX-FW763-4
  • 5 stars: 1 (100%)
S
Stanciu
Travel rod blank
Best travel rod blank so far,very well balanced and great action on the all length. Soft tip and backbone,really recommend this blank after I build few of them in different casting power. If you’re looking for a trout,perch blank this is the best. One think in mind,Consider the casting power from Rodhouse not the one from NFC !!!
