Black bass
Which rod for fishing black bass with a Wacky Rig? The technical guide
Quelle canne pour pêcher le black-bass en Wacky ? Le guide technique
Choosing the ideal rod for fishing black bass with the “Wacky Rig”. This blog article is a true guide that details the key characteristics and offers a selection of blanks to make the best possible technical choice for this simple but demanding technique.
Understanding Wacky Rig Fishing: a finesse approach for black bass
Definition of the Wacky Rig
The Wacky Rig consists of hooking a soft lure (worm or soft stickbait like a Senko) in its middle with a single hook, often a specific Wacky hook equipped with a weed guard to fish in cover. This rigging allows both ends of the lure to pulse freely with every twitch or during the fall, creating subtle and natural vibrations that attract even the wariest black bass.
Technical principles of the Wacky Rig
Slow, jerky animation with marked pauses and shakes.
Direct hookset at the slightest bite thanks to the action of the blank and the flexibility of the rig.
Usable weightless (without sinker) or with light weighting to fish deeper (Inch Wacky, Neko Rig).
Conditions of use
Heavy cover areas (weed beds, dead wood, shorelines).
Summer sight fishing or post-spawn periods.
Pressured or wary fish requiring a natural and discreet presentation.
Young anglers or beginners, thanks to its efficiency and simplicity.
Appropriate soft baits
Soft Stickbaits like Senko 4’’ to 5’’
Finesse worms, straight tail worms (for vibration)
Technical specifications of an ideal rod for Wacky Rig
Recommended length
6'6’’ to 7’3’’: allows precise casting along the shore while providing enough distance from a float tube or boat. Longer rods (7’+) favor long-distance casts and better fish control during hookset, especially from the bank. Shorter models (6'6") offer superior maneuverability in a float tube or heavily obstructed areas.
Recommended power
The blank’s power should match the weight of the lures frequently used as well as the fishing areas:
ML (Medium Light): approx. 3–12 g, perfect for weightless Wacky fishing or with inserts up to 3 g. Comfortable for animating straight tail worms or finesse worms up to 5’’.
M (Medium): Suitable for classic Senko fishing or in snaggy areas.
▶ Rodhouse Tip: For finicky fish, choose ML. Its softer tip acts as a buffer and helps avoid losing fish during hookset.
Blank action
Fast to Regular-Fast: Tip sensitivity to detect subtle bites, progressive action to absorb hooksets and reduce break-offs with light lines.
Extra-Fast: For long casts or hooksets at distance, but potentially harsher on very thin braid/fluoro.
Slow/Regular: To be avoided – lacks speed for distance hooksets, especially in weightless fishing.
Rod type
Spinning recommended: Lightness, precision, easy casting with lures under 10 g. Essential equipment for finesse fishing.
Casting possible but technical and demanding – best reserved for baitfinesse experts or for power fishing.
Environment and configuration:
Float tube: Short rod (6'6’’ to 6'8''), fast action.
Boat: 6'8'' to 7’0'' for maneuverability.
Bank: 7' to 7’3'' for longer distance.
Selection of blanks suitable for Wacky Rig at Rodhouse
REVS 68 ML-SB
Length: 6'8’’
Power: ML (perfect weightless)
Lure weight: 3–10 g
Action: Fast
Advantages: Exceptional sensitivity, ultra-light blank, excellent resonance for subtle bites.
Blank weight: 48 g
Line rating: 6–12 lbs
Ideal for: Float tube, sight fishing, ultra-discreet shoreline fishing.
PPS72M Blank
Length: 7'2’’
Power: Medium
Action: Fast
Blank weight: 43 g
Line rating: 8–14 lbs
Lure weight: 5–25 g
Specifics: Great value for money, very versatile, balance between flexibility and reactivity.
Ideal for fishing denser structures or with larger Soft Stickbaits 6'' and above.
PPS73ML Blank (Rodbuilders' Republic)
Length: 7’3’’
Power: Medium Light
Action: Fast
Lure weight: 5–17 g
Blank weight: 50 g
Long casts, round in the fight, excellent power reserve
Recommended rod setup and configuration
Recommended spinning setup
Spinning is recommended here to achieve maximum precision in lure animation and hookset accuracy. A setup with a short handle resting on the forearm and fitting into the crook of the elbow is ideal for accurate, fast casts and during animation phases.
Recommended line
Thin braid (PE 0.6 to 0.8, or 8–10 lbs) for distance and bite detection. Paired with a fluorocarbon leader of 6–10 lbs for discretion and abrasion resistance.
Wacky hook and accessories
Specific Wacky hook size 2–4, weedless if needed.
O-ring (silicone ring) recommended to extend the life of soft baits.
Conclusion
Choosing a rod for Wacky Rig fishing on black bass comes down to finding the perfect balance of sensitivity, lightness, and action. The Rodhouse-selected blanks cover the full range of needs for the most demanding anglers, whether from shore or boat.
Products of this article
SKU REVS68ML-SB
Brand Rainshadow
Range Revelation
Weight (g) 48.0
Target species Zander / Pike-perch, Perch, Black bass, Sea bass, Shad
Recommended techniques Street fishing, Minnow jerkbait, Bottom bouncing, Topwater
Action Fast
Length (cm) 203.0
Number of pieces Single-piece
Blank power 3-10 g (6-12 lb)
Butt measurement (mm) 10.82
Tip measurement (mm) 2.0
Recommended tip 4.5-2
REVS 68 ML-SB
139,20€83,52€
Brand Rodbuilders' Republic
Material Tresse
Weight (g) 52.91
Length (m) 150.0
OD1 0.12
Strength 6 kg
Prodigy X8 Braid
(24)
29,90€
SKU FLUO-PL-0.180
Material Fluorocarbon
Weight (g) 23.76
Target species Truite
Length (m) 50.0
Category Pêche des carnassiers en eau douce
OD1 0.18
Strength 5.3 lb
Fluorocarbon Prodigy Lines
(8)
14,90€
SKU Statement 722 Original
Range Prodigy
Weight (g) 42.0
Target species Sea bass, Zander / Pike-perch, Perch, Shad, Black bass
Recommended techniques Street fishing, Bottom bouncing, Minnow jerkbait, Topwater, Finesse
Action Fast
Length (cm) 217.0
Blank power 3-15 g (6-12 lb)
Butt measurement (mm) 12.98
(14)
184,80€
Spinning Rod WKS Statement 722 2m18  (3 - 15 g)
SKU WKS-STATEMENT 722
Range Prodigy WorkShop Series
Weight (g) 100.0
Target species Bar, Truite, Sandre, Perche, Alose
Recommended techniques Finesse, Jerkbait minnow, Kayak, Linéaire, Pêche à gratter
Action Fast
Length (cm) 218.0
Mounting Spinning
Number of pieces Monobrin
Ceramic Torzite
Frame Polished Dark Grey
469,00€
Spinning Rod WKS DS721-1 X-Ray 2m18  (2 - 10 g)
SKU WKS-DS721-1X-RAY
Weight (g) 100.0
Target species Perche, Black bass, Sandre, Bar, Alose
Recommended techniques Linéaire, Pêche à gratter, Dropshot, Finesse, Street fishing
Action X-Fast
Length (cm) 218.0
Mounting Spinning
Blank power 2-10 g (6-10 lb)
Ceramic Torzite
499,00€
All-In-One
Pack SJ 762-2 HMPack SJ 762-2 HM
SKU Entry-PackSJ762-2HM
Brand North Fork Composites
Target species Bar, Perche, Truite, Sandre, Black bass
Recommended techniques Jerkbait minnow, Pêche à gratter, Finesse, Spoon/Blade/Lipless, Dropshot, Kayak, Carolina
Action X-Fast
Length (cm) 229.0
Mounting Spinning
Number of pieces 2 brins
Blank power 3-12 g (6-10 lb)
Pack SJ 762-2 HM
386,27€
Frequently Asked Questions
Peut-on utiliser une canne casting pour le wacky ?
Oui, en baitfinesse seulement (canne casting UL/ML, moulinet spécifique). La spinning reste la référence pour le wacky classique.
