Rodhouse blog
International reports
Fishing trips
Library
Recent articles
13 articles
Comment choisir son moulinet casting Lew's ?
Aug 13, 2026
How to choose your Lew's baitcasting reel?
Gear ratio, braking system, weight and drag power: the four criteria that decide which baitcasting reel to buy. A comparison of the five Lew's reels in the R...
Pêche du Black Bass au jig : notre guide complet
Aug 7, 2026
Black bass jig fishing: the complete guide
Silicone or rubber, arky or football head, weight and trailer: how to set up your rubber jig for the spot, then the three retrieves that trigger bites.
Black bass : six leurres qui couvrent l'essentiel de votre saison
Aug 7, 2026
Black bass: six techniques and the lure to rig for each
Jig, craw on a Texas rig, chatterbait, frog, finesse worms and suspending jerkbait: the six techniques that cover a black bass season, the situation that cal...
Mid-strolling : la technique de pêche des poissons suspendus
Jun 30, 2026
Mid-strolling: the technique for catching suspended fish
Mid-strolling is a Japanese finesse technique that targets suspended fish with a soft lure worked through the mid water column. Here are the method, the gear...
WKS-PPS66MH-XO : le PPS 66 MH rallongé par la XO Skeleton pour la pêche du bass
Jun 23, 2026
WKS-PPS66MH-XO: the PPS 66 MH extended by the XO Skeleton for bass fishing
A close look at the WKS-PPS66MH-XO: the PPS 66 MH blank extended to 2.18 m by a carbon XO Skeleton handle, built for black bass in heavy cover (Texas rig, ru...
La WKS-PPS66MH : la canne Predator Patrol compatible pour le bass et le sandre en verticale
May 7, 2026
The WKS-PPS66MH: The Predator Patrol Rod Compatible for Bass and Zander Vertical Fishing
The flagship of the Predator Patrol range from Rodbuilders' Republic, the WKS-PPS66MH has established itself as a high-precision all-round rod. Largemouth ba...
Zoom sur la WKS-DS721-1 X-Ray : La quintessence de la résonance et de la légèreté
Feb 9, 2026
Spotlight on the WKS-DS721-1 X-Ray: The Quintessence of Resonance and Lightness
If you’re looking for a “light” rod that can turn every vibration into an electric jolt in your wrist, you’ve come to the right place. Today, we present the ...
Soies Fly Patrol Lines Long Shot Taper #8-9-10
Feb 4, 2026
With the LST 8, 9 and 10, we clearly enter the realm of pure streamer fishing. Moving the mass of a streamer and overcoming its aerodynamic drag requires wei...
Soies Fly Patrol Lines Long Shot Taper #5-6-7
Feb 4, 2026
Fly Patrol Lines Long Shot Taper Fly Lines #5–6–7
For many fly anglers, a floating line in weight 5 will be the main tool—and sometimes the only one—of their passion. From such lines, the first expectation i...
