Building your own rod wrapping jig: a step by step plan
Building a rod wrapping jig takes little more than a board, a few brackets and some felt. Here is the build plan, the tension setting and the limits of the home made version.
Gear ratio, braking system, weight and drag power: the four criteria that decide which baitcasting reel to buy. A comparison of the five Lew's reels in the R...
Silicone or rubber, arky or football head, weight and trailer: how to set up your rubber jig for the spot, then the three retrieves that trigger bites.
Jig, craw on a Texas rig, chatterbait, frog, finesse worms and suspending jerkbait: the six techniques that cover a black bass season, the situation that cal...
A close look at the WKS-PPS66MH-XO: the PPS 66 MH blank extended to 2.18 m by a carbon XO Skeleton handle, built for black bass in heavy cover (Texas rig, ru...
The flagship of the Predator Patrol range from Rodbuilders' Republic, the WKS-PPS66MH has established itself as a high-precision all-round rod. Largemouth ba...
Over the years, certain blanks become indispensable references and find their way into countless rod builders’ arsenals. Far more rarely, an entire series le...
