Building your own rod wrapping jig: a step by step plan
Building a rod wrapping jig takes little more than a board, a few brackets and some felt. Here is the build plan, the tension setting and the limits of the home made version.
Two Rodhouse Pro-Staffs, two strategies against the Bréhat currents: discovering new water for one, meticulous pre-fishing for the other. The story of a dema...
Silicone or rubber, arky or football head, weight and trailer: how to set up your rubber jig for the spot, then the three retrieves that trigger bites.
Same DNA as the legendary Statement 724, but with a power that changes everything. The WKS-Statement727 pushes the concept up to 50 g and opens the door to d...
Between the Statement 722 and the 724, a link was missing. The WKS-R663-XO has filled that gap with flying colours. Built on the R 663-1 blank from Rodbuilde...
If you’re looking for a “light” rod that can turn every vibration into an electric jolt in your wrist, you’ve come to the right place. Today, we present the ...
When it comes to fooling predators that feed on the bottom or hold right above it, bottom-scratching is a first-class presentation. To be effective—and avoid...
Over the years, certain blanks become indispensable references and find their way into countless rod builders’ arsenals. Far more rarely, an entire series le...
The event did not go unnoticed by those who regularly hang out on social media: Rodhouse claimed the top two podium spots at the Crouesty Fishing 2025. When ...
Sea bass fishing at night: a captivating nocturnal adventure. Immerse yourself in the mysterious world of Sea bass fishing. Discover the necessary equipment,...
