Build your first custom fishing rod
Monter sa première canne à pêche personnalisée
It's easy to get started with rodbuilding
Want to build your own fishing rod, but don't know where to start? With a little patience and the right tools, anyone can build their own rod. It's a unique opportunity to personalize your equipment, while discovering the Pleasure of rodbuilding, a discipline as technical as it is rewarding.
In this article, we offer you a complete package that brings together everything you need to get started in rodbuilding: a quality blank, handle elements, Guides and a set of specialized tools to get you started. Whether you're a novice or a seasoned do-it-yourselfer, this kit has been carefully selected to enable you to build your first rod with ease and provide you with all the basics you need for rodbuilding.
What's more, to guide you step by step through the process, a detailed instructional video is included. Every step of the way, from assembling the blank to fitting the Guides and adjusting the handle.
Ready to take up the challenge and assemble your first custom fishing rod? Follow the guide!
Start the configuration
An easy-to-build package
To get off to a good start in rodbuilding, it's essential to start on a solid footing, with the right equipment. That's why we've designed this complete blank pack, used in Rodhouse training courses, to give you everything you need to build your first rod without any hassle.
This kit has been thought through to the last detail, so you don't have to worry about a thing. All the elements are included: a blank from the world-renowned North Fork Composites brand, renowned for the quality of its products and its innovations. Designed by Gary Loomis, a true legend in the world of carbon, this blank is perfect for a first project, combining ease of assembly with high quality.
In addition to the blank, you'll find in this pack all the essential components: Guides, handle, and all the accessories needed for assembly. Whether you're a novice or simply want to hone your skills, this kit has been specially designed to guide you step by step towards success. You won't need anything else, everything is included so you can concentrate on learning and enjoying building your own rod.
This project is the perfect opportunity to get your hands dirty, with accessible assembly and suitable materials. Thanks to this complete kit, you'll be able to build a high-performance fishing rod while discovering the Pleasure of custom rodmaking.
All-In-One
Pack SB 604-1 SM
Pack SB 604-1 SM
Pack SB 604-1 SM
200,08€
Rapport Qualité/Prix
Discrétion
Polyvalence
Progressivité
Prepare your equipment
To successfully assemble your first rod, you need the right tools. That's why we've selected several rodbuilding tool packs, each designed to meet different levels of need and comfort. Whether you prefer to DIY your own equipment or opt for a turnkey solution, there's a pack to suit your project.
  • Pack Start: This pack contains all the essential tools to get you started, but requires you to create your own assembly bench. It does not include a reamer (handle adjustment tool) or a dryer (varnish dryer). If you like to do-it-yourself and want an economical solution, this pack is ideal. To help you, a detailed article on how to build an Assembly bench is available on our blog.
  • Medium Pack: Designed for those who want a little more comfort without the need to build a few tools. The Medium pack includes everything in the Start pack, plus a chuck to facilitate the connection between motor and rod, and a pack of reamers to fine-tune your rod's handle. The Medium pack still requires the manufacture of an Assembly bench.
  • Premium Pack: If you want a complete, ready-to-use package, this pack is for you. It includes an Assembly bench and a high-performance dryer. This pack is perfect for those looking for comfort and ease of use, while guaranteeing professional results.
For those who want to make their own tools, we offer DIY (Do It Yourself) solutions on our blog.
Whichever package you choose, you'll have the tools you need to start rodbuilding with efficiency and Pleasure!
Summary of your configuration
Here is the detail of items to add to your cart.
Item Product name Price
Total
Note: The following configuration is not an already built rod. It is the set of elements that allow you to build your own fishing rod.
