North Fork Composites
Mounting a carbon handle: a highly effective choice
Explore carbon handles for fishing rods. Discover the benefits of these lightweight, durable handles, and how they can improve your comfort and control when fishing.
Monter sa poignée en carbone : un choix des plus efficace
By Stéphane Montailler
Thanks to BF Rods for the photos
Carbon grips and carbon grips: what are they?
For a few months now, Rodhouse has been offering carbon grips and handles to enhance your assemblies:
https://www.rodhouse.fr/fr/shop/elements-de-poignee/poignees-carbone
But why choose these new grips? What are they made of? What are their technical advantages and disadvantages? Let's review the parameters the parameters of these promising new grips...
Composition of carbon grips.
As their name the name suggests, these new grips are made of carbon; well, a carbon sheath which is used to cover a shimming element that can be adjusted to the diameter of the blank. to the diameter of the blank.
When the carbon carbon grip is offered with its cushioning element, the latter is made of foam foam, an ultra-rigid material with no elasticity, but also very light.
As you can see carbon outer shell, an ultra-rigid foam core, the grips in foam core, carbon grips are built for a single purpose: maximizing the transmission of information, the vibrations of the blank.
Technical benefits
The mass.
When it comes to maximizing to maximize the sound of a blank, anything that attenuates the vibrations vibrations transmitted by the blank should be avoided. This is where carbon grips come into their own. Quite simply, I rediscovered my 68MXF thanks to the use of these grips. The vibration transmitted is finer, more present. It was already very good with the EVA grips, it's simply amazing with the carbon grips.
Ease of use ease of use
Adjusting the internal diameter foam core is much easier and quicker than its cork or EVA counterpart. in cork or EVA. It even becomes a Pleasure to prepare because it's so easy. so easy.
The comfort
Carbon grips carbon grips come in a variety of forms. Soft Touch, raw weave touch", raw weave, these grips are very comfortable whatever the outside temperature. They're not cold in winter, nor hot in summer. It's just just perfect.
It should be noted that the "Soft Touch" feel of North Fork Composites grips is just unique, very soft, very pleasant.
Infinite infinite possibilities!
The carbon available from Rodhouse come in a variety of shapes, lengths and colors!
For the more can turn foam hearts and varnish a carbon sock to create their own carbon sock to create your own customized handles.
You can find a full tutorial on the Rodhouse Fanzone on Facebook: https://www.facebook.com/groups/RodhouseFanzone/permalink/450120249241813
Limits
In practice, carbon carbon grips are used to maximize feedback. However, there one area where this use could be questioned: crank fishing. crank fishing. In fact, cranks vibrate a lot and the use of a blank a blank with a tip capable of attenuating crank vibrations. vibration. If you want to avoid having too much vibration in your hand, avoid using grips. avoid using grips that maximize feedback.
Conclusion
Carbon grips are a guarantee of sound and efficiency. They are light, technical and very comfortable. They'll complement a blank chosen for its sound and maximize your fishing pleasure! and maximize your fishing Pleasure!
Try carbon grips is to adopt them!
4
  1. Bonjour Daniele, Merci pour votre commentaire ! Vous pouvez jeter un coup d’oeil au tutoriel sur le montage de la poignée dans lequel Tony vous explique comment choisir vos éléments ! Voici le lien : https://youtu.be/-ECHGZIMzp8
  2. il faudrait un tuto ou un guide pour bien choisir et comprendre les bagues et anneaux de finition 😀
  3. Bonjour Daniele, Merci pour votre commentaire ! Vous pouvez jeter un coup d’oeil au tutoriel sur le montage de la poignée dans lequel Tony vous explique comment choisir vos éléments ! Voici le lien : https://youtu.be/-ECHGZIMzp8
  4. il faudrait un tuto ou un guide pour bien choisir et comprendre les bagues et anneaux de finition 😀
